TwinTurbo.NET: Nissan 300ZX forum - Oh, good call actually: well, the balance tube may actually
Subject Oh, good call actually: well, the balance tube may actually
Posted by evan_aggie on October 05, 2012 at 3:51 PM
  This message has been viewed 135 times.
In Reply To Doesn't the passenger turbo feed the driver side cylinders.. posted by TTZ2NV(EPTmotorsports) on October 05, 2012 at 10:30 AM
Message share some of the smoke between the two...hard to say.
That is a good point on the PCV! So, basically, what I've done at the moment (and yes this is probably not 100% correct) is leave my intake valve covers open to atmosphere. Ash does this and puts filters on them, which I still need to add. Then I took the exhaust valve cover ports, one which is capped facing the driver side PCV, and the 2nd at the rear facing perpendicular I've run a 5/8" hose to a catch-can. Again, both PCV valves were capped with rubber.
