TwinTurbo.NET: Nissan 300ZX forum - I tested the fuses per your method and
Subject I tested the fuses per your method and
Posted by 1911a1 on October 04, 2012 at 5:07 PM
  This message has been viewed 293 times.
In Reply To You can test a fuse while it is still plugged in. posted by Gordo 93TT Daytona on October 03, 2012 at 12:13 PM
Message I had previously checked the voltage at the fuse socket and was getting voltage and the fuse tested good with an ohm meter. But when I followed your method, I wasn't getting voltage through the 10a Illumina fuse. I changed the fuse and problem solved.
Fuses and lamps were the first thing I checked. I don't understand how a fuse would test good with a meter but not provide a voltage path. I don't think it was the fuse seating because I had it out twice. All is working properly now.
Thanks for the help! Something new learned.
