TwinTurbo.NET: Nissan 300ZX forum - Wait. Are you STUCK stuck on higbeams? There is a relay
Supermario680 (WI)
on October 04, 2012 at 10:15 AM
You can test a fuse while it is still plugged in.
posted by Gordo 93TT Daytona
on October 03, 2012 at 12:13 PM
That switches them up front. Also separate fuses for hi and low. Sounds silly but have you checked the front bulbs with a meter? I once had 3 go out at once on my old Na after I sold it.
No low beams and No tail lights ?
1911a1
19:03:23 10/02/12
Re: No low beams and No tail lights ?
MrHypnotik
19:43:12 10/02/12
Re: Re: No low beams and No tail lights ?
MrHypnotik
19:48:47 10/02/12
10A Illumination fuse may be at fault
Drk93TT
19:49:49 10/02/12
Re: 10A Illumination fuse may be at fault
aroche
20:31:28 10/02/12
use a test light cuz the fuse may not look bad but is (n/m)
craigz96tt
10:50:16 10/03/12
Gordo 93TT Daytona
12:13:10 10/03/12
Wait. Are you STUCK stuck on higbeams? There is a relay -
Supermario680 (WI)
10:15:39 10/04/12
I tested the fuses per your method and
1911a1
17:07:55 10/04/12
Now I am confused. (n/m)
Gordo 93TT Daytona
20:40:39 10/04/12
Re: I tested the fuses per your method and
Supermario680 (WI)
06:48:14 10/08/12
