TwinTurbo.NET: Nissan 300ZX forum - Do a Power Balance test as someone mentioned above. Start it
Subject Do a Power Balance test as someone mentioned above. Start it
Posted by Supermario680 (WI) on October 04, 2012 at 9:44 AM
  This message has been viewed 150 times.
In Reply To Twin Turbo Start up Video posted by 300zxWpg on October 03, 2012 at 07:06 PM
Message Start it up. Let it idle and pull a coil pack connector ONE at a time and listen for a drop or change in RPM. the engine may also shake too. This is a good sign. It means that cylinder was working fine. And more on to the next. If you find one that does NOT change then you are missing either spark fuel or compression. Start by visually checking for spark. Narrow it down by 33%. After that then check for fuel and compression etc..
