TwinTurbo.NET: Nissan 300ZX forum - Check the locking collar rings on the FUCA to insure they
Subject Check the locking collar rings on the FUCA to insure they
Posted by Gordo 93TT Daytona on October 03, 2012 at 12:47 PM
  This message has been viewed 157 times.
In Reply To Loud click in front end...help. posted by Terayonneo on October 02, 2012 at 02:11 PM
Message are not cracked. They can break and allowing the threaded sections to move about. Second, check the two larger bolts mounting the tension rod bracket to the crossmember. While you are there, also check the four smaller bolts mounting the sway bar brackets to aforementioned T-rod bracket.
_________________________________________________
