TwinTurbo.NET: Nissan 300ZX forum - check the torque on the tension rod brackets
aliaZ
on October 03, 2012 at 6:51 AM
Loud click in front end...help.
posted by Terayonneo
on October 02, 2012 at 02:11 PM
if they are not torqued to spec the bracket can slip under load. Also check that the FUCA bolts are tightened to spec
Terayonneo
14:11:12 10/02/12
Check the torque on the brake calipers.
SuparexTT
15:33:24 10/02/12
I re-torqued the two front calliper bolts and it did not fix
Terayonneo
23:30:08 10/02/12
I have the same problem, and thought it was my coilovers,
evan_aggie
16:37:32 10/02/12
check the torque on the tension rod brackets -
aliaZ
06:51:58 10/03/12
mine started after installing coilovers and st sway bars. (n/m)
evan_aggie
07:10:01 10/03/12
check air guides on the tie rods they make a click if shifte (n/m)
craigz96tt
10:54:37 10/03/12
I don't have air guides on my Z. (n/m)
Terayonneo
16:43:42 10/03/12
if happens at brake tapping master cyll brace will fix (n/m)
craigz96tt
10:57:22 10/03/12
It doesn't happen when I brake and I already have a brace (n/m)
Terayonneo
16:42:51 10/03/12
Check the locking collar rings on the FUCA to insure they
Gordo 93TT Daytona
12:47:34 10/03/12
Thanks Gordo, I will try this today! And get back to you. (n/m)
Terayonneo
16:45:34 10/03/12
Terayonneo
22:53:08 10/03/12
It could also be the adjustable sway bar endlinks. Most
zQuikonE
12:42:29 10/04/12
