TwinTurbo.NET: Nissan 300ZX forum - 10A Illumination fuse may be at fault
Subject 10A Illumination fuse may be at fault
Posted by Drk93TT on October 02, 2012 at 7:49 PM
  This message has been viewed 269 times.
In Reply To No low beams and No tail lights ? posted by 1911a1 on October 02, 2012 at 07:03 PM
Message Next to clutch pedal at that fuse block, its a red 10 amp fuse.. if blown or loose in the socket that will cause the headlight issue.. also your gauges wouldnt light up. If fuse is blown there may be a issue with the circuit.. ie short to ground somewhere etc.
