TwinTurbo.NET: Nissan 300ZX forum - Re: Car will turn over & ECU flashes Code:34
craigz96tt
on September 30, 2012 at 9:32 AM
posted by MikeBaitZ
on September 28, 2012 at 04:11 PM
The wires on the connector get very brittle from the heat. Mine had a broken wire going into the harness so I replaced the male side and code went away. Good luck
MikeBaitZ
16:11:59 09/28/12
34 will put your car in safety boost, so you will only be
JonnyZ(SoCal)
16:42:02 09/28/12
Check your connectors, they may have swapped the O2 and your
Drunkpunk082
21:42:21 09/28/12
Re: Check your connectors, they may have swapped the O2 and your
MikeBaitZ
12:47:21 09/29/12
Yeah same thing. Connector is at the rear of the engine..
Drunkpunk082
19:05:52 09/29/12
You mean det sensor and vtc. O2 is a 3 wire connector (n/m)
ztunerz
22:28:01 09/29/12
Re: Car will turn over & ECU flashes Code:34 -
craigz96tt
09:32:31 09/30/12
