TwinTurbo.NET: Nissan 300ZX forum - "only lasts a second"
Subject "only lasts a second"
Posted by aliaZ on September 29, 2012 at 11:50 PM
  This message has been viewed 125 times.
In Reply To Could be lifters but.. posted by Drunkpunk082 on September 29, 2012 at 07:33 PM
Message :they normally will continue to make noise after the car is warm.
depends. If the lifters have bled down because they're worn it would only take a second to pump back up once oil pressure is applied. If the check valve was stuck open, it would continue to make noise after startup
"Only lasts a second" pretty much rules out VTC gears, Piston slap, oil pickup is bent/pan is bent, or other oil starvation issues.
