TwinTurbo.NET: Nissan 300ZX forum - Based on CZP's site,
Subject Based on CZP's site,
Posted by PiotrC70 on September 29, 2012 at 11:06 AM
  This message has been viewed 232 times.
In Reply To Speed Sensor Replacement on JDM TT Trans? posted by imelmo on September 29, 2012 at 08:13 AM
Message they're the same for all years. Replacement is ridiculously simply. Unscrew the 2 bolts, slide the assembly out (which has a plastic gear at the end of it), slide new assembly in and tighten the screws down.
Are you unbolting the tranny from the engine or is everything already in? If you're not unbolting the tranny, the only other thing you COULD change out although most NEVER do, is the tranny mount located at the rear of the transmission. They're a bit pricey but if they've never ever been changed, you might as well.
1993 TT. R.I.P. 09.15.2010
