TwinTurbo.NET: Nissan 300ZX forum - Few things to check/change
Subject Few things to check/change
Posted by RobZ32 on September 28, 2012 at 11:34 AM
  This message has been viewed 148 times.
In Reply To Re: My twin turbo z wont rev over 1000 rpms posted by South Florida Z on September 28, 2012 at 11:12 AM
Message Check your MAF and MAF connector (car was sitting for a while might need cleaning)
Check your TPS make sure the connector is free of corrosion and that the sensor is working properly.
Check your CAS
Check your PTU and PTU harness make sure the connector is free of corrosion and that no wire are splice/cut
Since the car was sitting for a long time changing the fuel filter will help too. If the issue persist after performing all of the above you might want to start thinking about replacing your fuel pump.
If you are not familiar with the car a quick search here will tell you the location of the parts mentioned above. Hope this helps.
Rob
It's never "DONE", just finished enough to drive :-) - BigTDogg
(MA)
