TwinTurbo.NET: Nissan 300ZX forum - Clutch not engaging problem...help
Subject Clutch not engaging problem...help
Posted by z32TT_ on September 27, 2012 at 7:00 PM
  This message has been viewed 241 times.
Message Ive got a southbend flatface stage 4 kit.
Today after doing a pull and shifting into 2nd I noticed it took some effort..few seconds later it wouldnt even go in any gear. Pulled over an tried to shift gear and it didnt want to go in "any" gear.
Turned the car off, shifts fine into all gears.
Also noticed that the car would start/crank without even pressing the clutch in whereas it would always need to be pressed before I turned the key.
Put it in 1st with the clutch pressed in..cranked the car and it would move/jump.
Checked the fluid it was fine, but not the cleanest, pretty dark.
Bled from the line under the hood..no difference.
Tomorrow Ill try bleeding from the slave cylinder and inspecting that and the fork.
Anything else? Anyone experienced this?
