TwinTurbo.NET: Nissan 300ZX forum - Once sway bars are disconnected, the front lower arm drops
Subject Once sway bars are disconnected, the front lower arm drops
Posted by Gordo 93TT Daytona on September 24, 2012 at 4:35 PM
  This message has been viewed 252 times.
In Reply To Used floor jack to force wheel hub down (for strut swap)... posted by earthpunk on September 24, 2012 at 01:39 AM
Message far enough to pull the spring shock assy out w/o any interference. In the rear, use a 2x2 wedged into the lower arm, and put a little downward pressure with your knee moving the hub assy down until there is clearance to remove the spring shock assy. Disconnecting the sway bars is the key. After that, spring shock removal is easy.
_________________________________________________
