TwinTurbo.NET: Nissan 300ZX forum - Can't recall on the VTC but..
Subject Can't recall on the VTC but..
Posted by Drunkpunk082 on September 24, 2012 at 3:16 PM
  This message has been viewed 185 times.
In Reply To A few minor issues after pulled plenum posted by tian2bing on September 24, 2012 at 11:02 AM
Message They are interchangeable, just make sure the drivers side is hooked to the drivers side connection. You don't want to swap connectors but the actual VTC selenoids are identical.
As far as the vaccum connector, I need more details. Are you talking about the PCV valve or the connector with the curved connection near the top of the plenum? If its the PCV valve, replace it (should replace when plenum is off, cheap part) put some thread tape on it and screw it in tight. If its the one closer to the top then just remove it, clean it up, and reinstall with thread tape.
You shouldn't need RTV on those connections, but I guess it won't hurt anything.
