TwinTurbo.NET: Nissan 300ZX forum - Re: I believe you're correct starer solenoid in d/s fender well
aroche
on September 23, 2012 at 9:23 AM
I believe you're correct starer solenoid in d/s fender well (n/m)
posted by craigz96tt
on September 23, 2012 at 08:43 AM
The relay will be here on Tuesday. Its quite easy to get to, just turn the wheel all the way, unscrew the fender liner and its right there.
Starting/Electrical System issue
aroche
14:23:17 09/22/12
I would go over all the grounds and clean any corrosion and
JonnyZ(SoCal)
17:07:06 09/22/12
Re: I would go over all the grounds and clean any corrosion and
aroche
20:54:23 09/22/12
Seems to me there are one of two things happening--
jzack
23:15:59 09/22/12
Re: Seems to me there are one of two things happening--
aroche
09:14:32 09/23/12
Except that in Key 1 position the starter isn't engaged
jzack
11:05:41 09/23/12
Re: Except that in Key 1 position the starter isn't engaged
aroche
11:15:08 09/23/12
After thinking about this a little more -- much of what
jzack
23:49:40 09/22/12
Re: After thinking about this a little more -- much of what
aroche
09:21:10 09/23/12
craigz96tt
08:43:53 09/23/12
Re: I believe you're correct starer solenoid in d/s fender well -
aroche
09:23:20 09/23/12
Re: Starting/Electrical System issue
aroche
18:40:17 09/23/12
Thx for posting - guessing that relay was stuck closed,
jzack
22:44:30 09/24/12
