TwinTurbo.NET: Nissan 300ZX forum - Seems to me there are one of two things happening--
Subject Seems to me there are one of two things happening--
Posted by jzack on September 22, 2012 at 11:15 PM
  This message has been viewed 183 times.
In Reply To Starting/Electrical System issue posted by aroche on September 22, 2012 at 02:23 PM
Message either the car is putting some very high load on the battery or somewhere in the battery cabling there's a less than ideal connection (ie., battery positive cabling perhaps?).
When you tried to jump start the car where was the ground connection applied - car's battery post or someplace else? If battery post - try another location that's a good ground. See if that helps?
On the high loading issue -- maybe something funky with the starter? Perhaps pull that and have it tested? Really stumped on why the key in Pos 1 draws the battery down so low? I'd look over the car's circuit diagram and trace out all the connections made with the ignition key in position 1 -- might help to pin down some other places to check?
