TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Boost leak test results. Very low vacuum
Subject Re: Re: Boost leak test results. Very low vacuum
Posted by Glooj on September 20, 2012 at 5:58 PM
  This message has been viewed 263 times.
In Reply To Re: Boost leak test results. Very low vacuum posted by Glooj on September 20, 2012 at 12:58 PM
Message Any insights? Ideas? Anyone?...
I took the Air regulator off and inspected it and ohm tested it. It was 75 ohms, exact on with stock specification. I took it apart and it seemed to have full functionality and was able to open and close with no holdups or gunk in there.
I thoroughly cleaned the throttle bodies, set the TPS to .457 volts as per the writeups on this site and NICOclub, and cleaned the PTU and CAS (both of which showed absolutely no signs at all of any corrosion or problems). I would set the timing but I can't get the car to idle long enough to do it. I don't know what the problem could be...
