| Subject |
Re: Re: MAF, PTU, CAS, Plugs, plug gap, boost leak, injectors |
| Posted by |
MaxxAction on September 20, 2012 at 5:47 PM |
This message has been viewed 274 times. |
| In Reply To |
Re: MAF, PTU, CAS, Plugs, plug gap, boost leak, injectors posted by Fatal on September 20, 2012 at 07:07 AM |
| Message |
Buy an inner tube.... Cut two 5x5 inch squares out of it. Pull the maf or mars, clamp the rubber over the breather openings. Use an air gun and a piece of hose on one of the nipples on the balance tube to put the air in, listen for leaks. You can turn your key on and use your boost gauge to check the pressure.
| Follow Ups |
- 300zx cutting out above 5700 RPM. Help! - Fatal
16:43:16 09/17/12- MAF, PTU, CAS, Plugs, plug gap, boost leak, injectors (n/m) - Summeronthechain (MN)
20:31:26 09/18/12
- Re: MAF, PTU, CAS, Plugs, plug gap, boost leak, injectors - Fatal
07:07:41 09/20/12- Re: Re: MAF, PTU, CAS, Plugs, plug gap, boost leak, injectors - MaxxAction
17:47:24 09/20/12
Post a Followup |
