TwinTurbo.NET: Nissan 300ZX forum - Re: Boost leak test results. Very low vacuum
Subject Re: Boost leak test results. Very low vacuum
Posted by Medallion Man on September 20, 2012 at 6:18 AM
  This message has been viewed 309 times.
In Reply To Boost leak test results. Very low vacuum posted by Glooj on September 19, 2012 at 11:03 PM
Message not that I'm saying it's this for sure but...
check the balance bar, it is a common problem to put it back on with one of the brackets under the bar instead of on top.
best of luck finding he problem... you could also try using smoke matches to find the leak (not sure if they use them over your side of the pond).
