TwinTurbo.NET: Nissan 300ZX forum - Re: PTU connectors?
Re: PTU connectors?
Fatal
on September 20, 2012 at 5:53 AM
PTU connectors?
posted by Rocket man
on September 18, 2012 at 07:38 PM
I relocated the ptu and when I did I checked the connections and they looked OK but like you said its quick and free so ill clean the connections just to be safe
300zx cutting out above 5700 RPM. Help!
Fatal
16:43:16 09/17/12
Re: 300zx cutting out above 5700 RPM. Help!
MaxxAction
19:15:11 09/17/12
Re: Re: 300zx cutting out above 5700 RPM. Help!
Fatal
19:28:07 09/17/12
Re: Re: Re: 300zx cutting out above 5700 RPM. Help!
MaxxAction
20:51:10 09/17/12
Re: Re: Re: Re: 300zx cutting out above 5700 RPM. Help!
Fatal
22:43:47 09/17/12
Re: Re: Re: Re: Re: 300zx cutting out above 5700 RPM. Help!
MaxxAction
06:22:16 09/18/12
When did it start? When's the last time you changed plugs? (n/m)
JDAVE
07:37:46 09/18/12
Re: When did it start? When's the last time you changed plugs?
Fatal
05:35:41 09/20/12
Is this happening any lower rpm ever? Do you have a wind....
craigz96tt
09:58:18 09/18/12
Re: Is this happening any lower rpm ever? Do you have a wind....
Fatal
05:44:06 09/20/12
Re: Re: Is this happening any lower rpm ever? Do you have a wind....
craigz96tt
10:47:21 09/21/12
have you verified you fuel pressure under load?
aliaZ
12:13:55 09/18/12
PTU connectors?
Rocket man
19:38:58 09/18/12
Re: PTU connectors? -
Fatal
05:53:51 09/20/12
MAF, PTU, CAS, Plugs, plug gap, boost leak, injectors (n/m)
Summeronthechain (MN)
20:31:26 09/18/12
Re: MAF, PTU, CAS, Plugs, plug gap, boost leak, injectors
Fatal
07:07:41 09/20/12
Re: Re: MAF, PTU, CAS, Plugs, plug gap, boost leak, injectors
MaxxAction
17:47:24 09/20/12
Re: Re: Re: MAF, PTU, CAS, Plugs, plug gap, boost leak, injectors
Fatal
17:08:17 09/24/12
