TwinTurbo.NET: Nissan 300ZX forum - Puzzled and Need Help!!!
Subject Puzzled and Need Help!!!
Posted by krstull93 on September 19, 2012 at 4:41 PM
  This message has been viewed 209 times.
Message My car has had a vac leak for a while and couldnt figure out why. My plenum gasket rubber seal was blown out. I ordered the z1 vac tester to check for leaks before that...The gauge sits on 2.5psi?? It wont move when I try to put pressure but I had a leak..So I replaced the gasket today and when I went to test it again, STILL LEAKING.. The same rubber seal blew out on the new gasket. What could be the problem? To much pressure while testing? Seating bad? Gauge not reading at all and over doing it?
