TwinTurbo.NET: Nissan 300ZX forum - hicas light, taillight light, ebrake light,dimmed alternator
Subject hicas light, taillight light, ebrake light,dimmed alternator
Posted by fuzzymonkey on September 19, 2012 at 11:40 AM
  This message has been viewed 253 times.
Message light, stock boost gauge don't work. W T F, annoying. When I remove bulb check relay, lights turn off and still come on during proper operation (low ps fluid, hicas light still comes on without the relay).
What could be my problem here? I read numerous *older* threads that the engine cont fuse is the cause of it, however the fuse is in good shape (I did try swapping it anyways). I also read on one thread that if I remove that fuse, the idle should drop, which mine doesn't and I did have a hunch that my iacv was not working properly.
Those dash lights go off every so often, when clutch pedal is pressed, but come back on as soon as I put in gear and press the gas pedal (still off when revving). There is no wiring on the clutch pedal (no crusie, no starter switch, nothing).
What could be my issue? Is there another oem location with a fuseable link on the engine cont wire somewhere? I've checked every single fuse and they're all good.
I hate giving electricians money. It's hit or miss, $20 or $250.
