TwinTurbo.NET: Nissan 300ZX forum - PTU connectors?
Subject PTU connectors?
Posted by Rocket man on September 18, 2012 at 7:38 PM
  This message has been viewed 267 times.
In Reply To 300zx cutting out above 5700 RPM. Help! posted by Fatal on September 17, 2012 at 04:43 PM
Message I had a similar problem where when driven hard (full load/high rpm) the engine would cut in and out. Seemed to get worse when hot. I would let the car cool off and it would be fine for a while.
It turned out to be corroded PTU connections. My theory is that at low rpm the connections were good enough, but at high rpm when all those connections are firing faster it just couldn't handle the higher electrical loads. I'm not sure if that theory is sound, but I know after I clean those connectors it never happened again.
Like the boost leak check, it's an easy/free first thing to try.
Good luck.
90 300zx TT 13.285@106.08 (old stock turbo set up)
94 Camaro Z28 13.751@101.83
03 WRX 13.973@94.88
02 Mazda MPV; four kids and a wife don't fit in the Z.
90 240sx (sold) 16.9@87
