TwinTurbo.NET: Nissan 300ZX forum - Can a bad Power Transistor Unit (PTU) cause you RPM gauge to
Subject Can a bad Power Transistor Unit (PTU) cause you RPM gauge to
Posted by NismoDHS on September 18, 2012 at 3:55 PM
  This message has been viewed 516 times.
Message stop working and make your car barely run after you remove the key? ...I ask b/c my car currently barely starts up and runs after cranking it...then it starts shaking really bad (I already know I have 1 bad injector that contributes to the shaking)...I have no readings on the RPM gauge....then I remove the key out of the ignition and it keeps running (barely)...but sounds like it's running off one cylinder unless I really hit the gas with the clutch in!.... I only got a 21 reading on the Diagnostics, so I'm assuming the CAS is good.... I'm just curious if I'll have another issue once the new PTU I ordered comes in?...or will that also fix the RPM gauge issue?
