TwinTurbo.NET: Nissan 300ZX forum - Here a good one, Fuel Pressure Drop and engine stall w/ cold
Subject Here a good one, Fuel Pressure Drop and engine stall w/ cold
Posted by 93 Blue Z32(NC) on September 17, 2012 at 11:30 PM
  This message has been viewed 343 times.
Message NA to TT 300zx
TT controller and TT fuel pump installed
If z has been sitting turn key on (fuel press 45) start z up runing good for 5 second then fuel gauage shows fuel presser droping down to 10 psi and engine stalls.
turn key and z might do the same thing again for one or two more times then runs good.
Hot start is fine. just has fuel pressure drop off if z sits for hr or cold.
I changed ecu's out my z (same problem)
Put test light on white purple strip wire (got light power even when z dies for fuel pressure drop)
I did search this problem seems different from what I Read
Thanks for any help
