TwinTurbo.NET: Nissan 300ZX forum - Re: Clutch safety switch: I eliminated that function by
Subject Re: Clutch safety switch: I eliminated that function by
Posted by Gordo 93TT Daytona on September 16, 2012 at 2:25 PM
  This message has been viewed 257 times.
In Reply To Adjustable clutch pedal stop install location? posted by DomZ32TT on September 16, 2012 at 12:27 PM
Message disconnecting the leads it at the pedal pivot switch connector. Use a short length of wire bent in a 'U-shape" to close the circuit. Tape the exposed wire to prevent shorts, and zip tie it out of the way.
Tort Attorneys please note: I grew up before this safety function was mandated. Consequently, it is first nature for me to double check the trans is in neutral before I turn the key to start. If one forgets to do this, depending on what gear your in, the car will jump forward 6-10" before you catch it. So my advice to all readers is that this is not the best shortcut for you if your were born into a world of DOT mandated safety switches.
_________________________________________________
