TwinTurbo.NET: Nissan 300ZX forum - For a DD it is more important to isolate the subframe as
Subject For a DD it is more important to isolate the subframe as
Posted by Gordo 93TT Daytona on September 16, 2012 at 2:08 PM
  This message has been viewed 219 times.
In Reply To Subframe and diff bushings posted by buloushie on September 13, 2012 at 06:26 PM
Message ,,,opposed to the diff. The reason being that harshness, vibration and noise are generated by the drive axles, prop shaft, etc. and transmitted into the cabin. If your diff is solid (which most do not recommend by the way) then some of that HNV will be also absorbed by the softer subframe mountings.
You already have most of the suspension either spherical ball end links or poly; however, as noted above, much of that HVN is now being absorbed by the subframe mounts before it enters the cabin. To answer your question, I'd do both the diff and subframe in poly. But be prepared for much more noise into the cabin as a result.
_________________________________________________
