TwinTurbo.NET: Nissan 300ZX forum - Wiring re-route wisdom needed....
Subject Wiring re-route wisdom needed....
Posted by Z ONLY1 on September 16, 2012 at 9:06 AM
  This message has been viewed 231 times.
Message I have modified my plenum, so no longer use the those side brakets that mount alot of the wiring.
Passenger side is not much of a problem, however on the driver's side, there is that large hard plastic housing which use to connect to that metal bracket.... I have seen some pics where it looks like that plastic encasement is down by the frame rail and hardlines....that would be good to hide this monster, here is my question....
the only two wires I need to pull out and elongate are the two going to the TPS, I opened the casing and located these two wires and I believe it is the one that connects the TPS to the harness seems way to short if I place this enclosure down low...the one that connects to the front I think will be ok (I just started this so I did not get aggressive in de-looming back too far) the short wire has a splice (black wire) partially back which limits me gaining the length I think I need.
So, any write-ups on relocating this monster plastic protector, how have others relocated and to where and solve the TPS wire issue.
Thanks, trying to finish up to go to the SZ tuning November in St. Louis.
