TwinTurbo.NET: Nissan 300ZX forum - I disagree.
Subject I disagree.
Posted by Summeronthechain (MN) on September 15, 2012 at 11:32 PM
  This message has been viewed 236 times.
In Reply To Re: PCV Hoses posted by craigz96tt on September 15, 2012 at 08:39 AM
Message What you need to do is plug the hoses/PCV holes on the valves.
But 1/4 inch NPT plugs to replace the valves and some 1/2 inch caps for the hardlines.
Essentially what you have now is a vacuum leak when the manifold is under vacuum. That is, air is unmetered air is being sucked into the plenum via the PCV valves, which is getting it from the crankcase, which is getting it from your vented front hoses.
