TwinTurbo.NET: Nissan 300ZX forum - Wideband Reading
Subject Wideband Reading
Posted by Doug71zt(CAN) on September 14, 2012 at 1:11 PM
  This message has been viewed 338 times.
In Reply To Factory boost restrictors posted by Silens on September 14, 2012 at 03:37 AM
Message As for the wideband spike to lean mixtures when the throttle is closed, there is a fuel cut when the throttle is closed at higher rpm in most fuel injection systems, so the mixture goes lean when the throttle is closed. The system re-introduces fuel as the rpm comes down to idle. This stops the popping in the exhaust on over-run, saves a bit of fuel and allows the engine rpm to come down more quickly as there is no combustion.
