TwinTurbo.NET: Nissan 300ZX forum - Re: All good advise.....
Subject Re: All good advise.....
Posted by Medallion Man on September 14, 2012 at 11:59 AM
  This message has been viewed 269 times.
In Reply To Replace coolant temp sensor and clean MAF w/proper chem (n/m) posted by craigz96tt on September 14, 2012 at 09:43 AM
Message you might as well check all the connectors you can find/get to, its not that difficult and once cleaned if it's still bad you'll know the problem isn't that.
corroded connectors can cause all kinds of issues.
get the Timing checked again.
Not that I think it’s causing the misfire but I'd also do a vac/boost check (you can make a plug yourself cheap) see tech section.
have a look here...
[ http://www.pexcom.com.au/z32cms/e107_plugins/content/content.php?content.487 ]
bit of a read but might help...
[ http://www.pexcom.com.au/z32cms/e107_plugins/content/content.php?content.488 ]
