TwinTurbo.NET: Nissan 300ZX forum - Rear Main Seal Trouble Shooting
Subject Rear Main Seal Trouble Shooting
Posted by Summeronthechain (MN) on September 11, 2012 at 9:33 PM
  This message has been viewed 488 times.
Message Hey TT.net, I need your collective wisdom.
Issue: I have a leak from the rear main seal. It drips about a baseball sized spot over night. It runs down between the bellhousing and the oil pan.
Troubleshooting I've already done:
I realized this is a common leak, so I went ahead and pulled the trans. It looked like oil was dripping down the RMS and onto the ridge where the oil pan half-moon seal is. I replaced both with OEM. I put it all back together and drove it for a bit. Still leaked.
I then researched crankcase pressure via bad PCVs. So I replaced the PCVs and all 5 hoses with OEM hoses with OEM units. I don't really have any other symptoms of excess blow-by gas such as popping dipstick. Compression on the engine is in spec.
However this resulted in no change, the leak remained.
So then I thought I might have gotten a defective seal or installed it improperly, so I removed the trans and replaced the seal again. Yet the leak remains.
So I am out of ideas here. The car runs perfect otherwise. I am using Castrol Syntec 5W40 conventional oil.
Any other things to try before I go crazy?
