TwinTurbo.NET: Nissan 300ZX forum - Yes with key on should be close to 12v power and hear whine
craigz96tt
on September 11, 2012 at 10:15 AM
Should I get a 12 Volt reading on the pin connector of the
posted by NismoDHS
on September 11, 2012 at 09:44 AM
but if bad you won't get volts or whine when turned on. Same thing you pull out if changing fuel filter. More likely that's your issue rather than fuel pump was. It turns over but no fuel at all correct?
NismoDHS
09:44:41 09/11/12
Yes with key on should be close to 12v power and hear whine -
craigz96tt
10:15:21 09/11/12
Re: Looks like after hundreds of dollars later....
NismoDHS
13:05:01 09/11/12
No the relay opens and closes a circuit for a specific amt
craigz96tt
18:43:31 09/11/12
- I think my ECU may be messed up now...here's why:
NismoDHS
11:42:09 09/12/12
...also, just checked my ECU and it doesn't even go into
NismoDHS
14:06:50 09/12/12
Please post a follow up when repaired that's how we learn (n/m)
craigz96tt
10:51:22 09/11/12
