TwinTurbo.NET: Nissan 300ZX forum - Just tried to ground it out, but no luck...so then I
Subject Just tried to ground it out, but no luck...so then I
Posted by NismoDHS on September 11, 2012 at 9:38 AM
  This message has been viewed 257 times.
In Reply To Re: PLEASE HELP!...Fuel Pump issue! posted by ttsmokin on September 10, 2012 at 06:35 PM
Message decided to grab a multimeter and check the voltage on the pin connector that connects to the FPCU and I got no readings!...I should have got a 12 Volt reading, correct?...if so...and my Fuel Relay switch is good and reading 12 Volts, what could be the reason I'm not getting 12 Volts on the FPCU pins??
