TwinTurbo.NET: Nissan 300ZX forum - You can put them in test pipes.. However..
Subject You can put them in test pipes.. However..
Posted by Drunkpunk082 on September 09, 2012 at 3:16 PM
  This message has been viewed 297 times.
In Reply To Re: Why do you want to put them so close to the turbos? posted by Silens on September 09, 2012 at 12:58 PM
Message if he was still running the stock pre-cats it is NOT recommended to place them after the pre-cats. You want an unmodified/unobstructed reading. If your running down pipes/test pipes yeah you can put them farther downstream because its nothing but pipe between the sensor and turbo. But if you are using stock exhaust or pre-cats it needs to be before any catalytic material.
So since he decided to upgrade the pipes its really up to him. He can put it in either place just as easy during the upgrade.
