TwinTurbo.NET: Nissan 300ZX forum - Re: Hmm...
Subject Re: Hmm...
Posted by Cjw3 on September 06, 2012 at 11:20 AM
  This message has been viewed 184 times.
In Reply To Hmm... posted by inf on September 05, 2012 at 12:01 PM
Message When I was talking about checking TDC, I was wondering if the TDC marks on the Crank Pully might be wrong, and you are actually running with a Very Advanced Ignition Timing.. and you do not know it.. That can cause an increase in Idle Vacuum, and Increase in NOX readings.. with a 'Ruff Idle'..
Might want to double check the TDC mark on the Crank.. might be an issue.. just for reference, I doublechecked my '95 NA TDC marks on the Factory Pully and the Factory front Cover.. it was perfect..
Cj
