TwinTurbo.NET: Nissan 300ZX forum - Option 1 is the best way IMHO
Subject Option 1 is the best way IMHO
Posted by aliaZ on September 05, 2012 at 5:23 PM
  This message has been viewed 188 times.
In Reply To Preferred bench bleeding procedure for new master cylinder? posted by Under_Powered on September 05, 2012 at 05:16 PM
Message I don't think you'll ever get the air out with option 2
I bought some 8 inch pieces of brake line with the correct fitting, and screwed them into the master cylinder, and bent the lines around until they point into the master cylinder. I then attached some tubing to the brake lines so that the ends were submerged in brake fluid within the reservoir.
Install it, and pump the crap out of it until you see no more bubbles. Take off the 8 inch brake lines, and install the brake lines from the car.
