TwinTurbo.NET: Nissan 300ZX forum - I just fixed a bunch of leaks with an engine pull
Subject I just fixed a bunch of leaks with an engine pull
Posted by EUGENE on September 05, 2012 at 8:40 AM
  This message has been viewed 176 times.
In Reply To Video is worth 10000 words, even if it's 2 minutes long. posted by Silens on September 04, 2012 at 02:48 AM
Message Not sure if you're having any of the same leaks, but some of these places are pretty common and should be checked. I changed the following:
rear main seal
--was definitely leaking after probably far less than 60k miles
oil filter tree
--first I tried replacing some of the accessible copper washers, but had no luck in fixing the leaks. So, I ended up replacing the oil tree, o-ring, and gasket with new ones, which unfortunately require an engine pull
oil pan seal
--not sure if this was necessary, but did it anyway since the engine was already out
replaced rubber lines from oil cooler to engine block
--also not sure if this was necessary, but the old ones were hard and dirty
replaced 90 deg elbow between engine block and oil pressure sensor
--was definitely leaking, although you won't have this unless you also have larger aftermarket turbos like my Z1 675s
tightened leaky clocking bolts that hold turbo intake and exhaust sections together
tightened leaky oil drain flange bolts on bottom of turbos
