TwinTurbo.NET: Nissan 300ZX forum - does it even start or just crank?
Subject does it even start or just crank?
Posted by nissan300zxwork on September 01, 2012 at 6:27 PM
  This message has been viewed 216 times.
In Reply To Car wont idle or rev. posted by Jon300zx2+2TT on September 01, 2012 at 02:07 PM
Message Have spark? Try to start it with maf sensor unplugged so it runs off tps sensor? Make sure tps is in spec? Did you screw up orings on injectors? Possibly forgot a lower o ring in the rail when swapping injectors?(unlikelu but you never know) fuel pump primes with key forward? Smell gas when cranking?
Possibly didnt tighten ecu clip evenly when you chipped ecu or installed ecu? If you chipped ecu yourself mabe installed chip backwards?
You left out alot of info and have alot of common things that should be checked already that arnt on list of stuff you did check. There has to be something wrong for it to not start so best bet is to check fuel or spark an see whats missing. Unplug maf to let run on tps to make sure it wont start from leak on maf sensor. Make sure cas clip is tight, if it has no clip it will vibrate slightly an loose connection an make it not start.
