TwinTurbo.NET: Nissan 300ZX forum - Re: camshaft brackets
Subject Re: camshaft brackets
Posted by Cjw3 on September 02, 2012 at 10:23 PM
  This message has been viewed 173 times.
In Reply To camshaft brackets posted by inf on September 02, 2012 at 09:28 PM
Message Must go back in the SAME place.. as I remember, there are some casting marks ( Casting Stamps ? ) that will help tell position ..
I had a few 'Unknown Caps' that were not well marked on my replacement heads.. I pulled the Lifters and assembled the Cams in the heads.. if the Cam Journal Cap is in the wrong spot, the cam will not turn as you try to tighten the cap .. keep moving the caps around till you can get all the caps tight, and the cams still move FREELY.. NO DRAG.. if they drag, its not right.. should turn hand free even when the Caps are Torqued Up..
