TwinTurbo.NET: Nissan 300ZX forum - Start with proper master cyl rod adjustment
Subject Start with proper master cyl rod adjustment
Posted by Joe@ZSpeedperformance on September 01, 2012 at 8:55 PM
  This message has been viewed 254 times.
In Reply To Clutch bleeding problem posted by tt_703 on September 01, 2012 at 12:21 AM
Message If it is too tight or too loose it will never bleed correctly.
Make sure you have a little free play in the clevis with the pedal up, When you push the pedal there should be a small amount of pedal movement before the rod/clevis to the master starts to move.
