TwinTurbo.NET: Nissan 300ZX forum - How do I know if the MC is bad ? (n/m)
tt_703
on September 01, 2012 at 9:22 AM
The best way I've found to be sure all the air is out
posted by jzack
on September 01, 2012 at 08:25 AM
Clutch bleeding problem
tt_703
00:21:44 09/01/12
did you bleed the 2nd bleeder behind rf headlight?
Drk93TT
07:30:31 09/01/12
I did all that a good amount of time (n/m)
tt_703
07:57:58 09/01/12
jzack
08:25:09 09/01/12
How do I know if the MC is bad ? (n/m) -
tt_703
09:22:06 09/01/12
Often leaking or won't build pressure w/out the pedal
jzack
15:16:58 09/01/12
Start with proper master cyl rod adjustment
Joe@ZSpeedperformance
20:55:21 09/01/12
2nd the rod adjust and be sure slave hose is not leaking (n/m)
craigz96tt
08:00:21 09/02/12
Re: Clutch bleeding problem
craigz96tt
08:06:15 09/02/12
