TwinTurbo.NET: Nissan 300ZX forum - Re: PLEASE HELP!...Car won't start...no sound of fuel pump!
Subject Re: PLEASE HELP!...Car won't start...no sound of fuel pump!
Posted by ZTom on August 30, 2012 at 11:20 AM
  This message has been viewed 206 times.
In Reply To PLEASE HELP!...Car won't start...no sound of fuel pump! posted by NismoDHS on August 29, 2012 at 04:09 PM
Message You said the car wont turn over. Did you check the cold cranking amp on the battery? If battery is good turn the car to on position and unhook the fuel hose from the fuel filter to see if fuel shoot out, becarefull. If fuel does not shoot out then your fuel pump is not working. The fuel pump relay is on the driver side kick panel next to your left foot. Take out the cover and you should see the color green relay. I would replace it to rule out that it is no good. Then check your fuel pump. Let me know how it go.
