TwinTurbo.NET: Nissan 300ZX forum - PLEASE HELP!...Car won't start...no sound of fuel pump!
Subject PLEASE HELP!...Car won't start...no sound of fuel pump!
Posted by NismoDHS on August 29, 2012 at 4:09 PM
  This message has been viewed 308 times.
Message I recently had my A/C worked on (haven't had air in over 8 years!)...well I ran the A/C on full blast on the way home from the shop....parked the car in the garage...went to go somewhere an hour later and the car wouldn't turn over!....It made the sound of attempting to crank up, but never did....then I noticed when I turned the key I didn't hear the fuel pump sound....so I replaced the Fuel Relay Switch behind the driver's side kick panel...no luck...checked the Fuel Fuse by the battery...it's fine... then even removed the Fuel Pump from under the spare tire (it's a 2+2)...put 12 Volts to the pump and it made a sound....so doesn't that mean the pump is more than likely good?....given that I still don't hear the fuel sound, what else could be the reason that the car won't crank!? (battery is good...only thing I haven't checked is the fuel filter...but that shouldn't cause the fuel pump noise not to sound, correct?)...Any ideas???..read most post and stuff..no luck.....PLEASE HELP!
