TwinTurbo.NET: Nissan 300ZX forum - Re: Engine Pull
Subject Re: Engine Pull
Posted by ZBOOSTT on August 28, 2012 at 9:12 PM
  This message has been viewed 217 times.
In Reply To Engine Pull posted by mypak6 on August 28, 2012 at 10:36 AM
Message You will need a crows foot socket to remove the back A/C bolt and NEVER put that thing back in. You can use the autozone tools to borrow and remember reverse is tighten on the socket wrench.
I have done 5 engine pulls. Hated every one, but about to do it again. If your car is in a home garage, be sure your engine lift does not hit your garage door when it is all the way up. Do not pull the engine from the plenum. Use the side metal straps that bolt plenum to the block with the plenum off. They will bend a bit, but easily go back in place. Remove everything you can and replace everything possible the first time!!!
Tranny off first!
