TwinTurbo.NET: Nissan 300ZX forum - It isn't the drain line. However, I found what probably
Subject It isn't the drain line. However, I found what probably
Posted by evan_aggie on August 26, 2012 at 12:15 PM
  This message has been viewed 242 times.
In Reply To Re: Let me add, I did check the oil feed line. It seems fine. posted by MaxxAction on August 26, 2012 at 08:04 AM
Message caused the issue. *sigh*. I had a shop paper towel still blocking the oil return path in the oil pan (didn't go in) when I had put my silicone hose back on. I'm pretty pissed at myself right now.
Anyway, I'm just thinking, despite the oil restrictor, a blockage of the oil return path probably put too much oil pressure within the turbo and it started to leak...maybe even into the compressor housing. I'm taking the compressor air inlet pipe off to see. Man, that suckkkkks.
