TwinTurbo.NET: Nissan 300ZX forum - Re: Clutch pedal no resistance, clutch fork, slave cylinder issu
Subject Re: Clutch pedal no resistance, clutch fork, slave cylinder issu
Posted by Medallion Man on August 25, 2012 at 10:17 AM
  This message has been viewed 220 times.
In Reply To Clutch pedal no resistance, clutch fork, slave cylinder issu posted by jonting421 on August 25, 2012 at 09:59 AM
Message there is a possibility that pivot point has broken..
if you can get under the car and pull back the boot to see inside the bell housing you may be able to see the head (ball) at the end of the pivot has broken off.
unfortunately the best way to check for any damage in that area is to have the gear box out.
