TwinTurbo.NET: Nissan 300ZX forum - B4 pulling apart definately do a 2nd compression test >>>
Subject B4 pulling apart definately do a 2nd compression test >>>
Posted by ZUL8TR on August 24, 2012 at 3:36 PM
  This message has been viewed 204 times.
In Reply To Re: Re: Compression test.. i think im finished. posted by puchy on August 20, 2012 at 12:10 PM
Message with oil in cylinders compression test to see the gain if any. If no or minimal compression gain the problem could be leaky valves.
Also B4 pulling apart check the engine vacuum at idle and at 2000. At idle look for a very steady needle at 19 to 20" Hg and 2000 look for a very steady needle about 1"Hg higher.
Here are some tips on vacuum readings read the entire article. Use another vacuum gage besides the turbo gage you have:
[ [ http://www.atlanticz.ca/zclub/techtips/vacuum/ ] ]
ZUL8TR in Orlando,FL
