TwinTurbo.NET: Nissan 300ZX forum - Re: Re: follow up on resetting IACV and TPS
slcZ32
on August 24, 2012 at 2:26 PM
posted by Medallion Man
on August 24, 2012 at 03:31 AM
Yup just tried that, there was no effect on the engine. I will take the aac apart and clean it, after work. Just to make sure the aac is the black box that the idle control valve connects to with a hose right?
1990 NA idling issues, please help
slcZ32
23:45:22 08/22/12
Have you checked for codes?
JonnyZ(SoCal)
00:10:52 08/23/12
Re: Have you checked for codes?
slcZ32
00:40:32 08/23/12
forgot to meantion
slcZ32
01:00:41 08/23/12
Re: forgot to meantion
Medallion Man
02:37:47 08/23/12
Check and adjust the TPS using the pin probe method>
ZUL8TR
09:57:04 08/23/12
Re: Check and adjust the TPS using the pin probe method>
slcZ32
12:15:01 08/23/12
Yes provided you set the voltage to the specified amount >>
ZUL8TR
13:11:29 08/23/12
slcZ32
02:38:46 08/24/12
Medallion Man
03:31:51 08/24/12
Re: Re: follow up on resetting IACV and TPS -
slcZ32
14:26:55 08/24/12
Re: Re: Re: follow up on resetting IACV and TPS
Medallion Man
02:15:20 08/25/12
