TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Z32 NA power loss when warm
Subject Re: Re: Re: Z32 NA power loss when warm
Posted by Krazyd27(Houston) on August 24, 2012 at 9:59 AM
  This message has been viewed 193 times.
In Reply To Re: Re: Z32 NA power loss when warm posted by syphon0202 on August 23, 2012 at 09:42 PM
Message Doesn't always mean the sensor is bad, the connection to the det sensor is know to get corroded and cause problems. I would clean the connections as best I could. If and only if the sensor is fault you can contact Bernie and snag a denotation sensor and relocate it on the plenum if you don't want to pull it. Of course that's always only a temp fix, as opposed to actually replacing the main one.
